Transmit of a checkpoint message to the displayed peer has failed. Partial checkpoint information exchange between MLAG peers results in incorrect operation of the MLAG feature. Users may see either duplication or loss of traffic to the remote end of MLAG links.
This situation will usually correct itself as the checkpointing channel to the peer will be closed and re-opened at both ends. However, if the issue persists, please check if the ISC link is flapping. Else escalate to engineering.
Warning
Peer %vrid%:%peer%:: Checkpoint send failed with: %errormsg%
| Name | Type |
| vrid | VRID |
| peer | String |
| errormsg | String |
